Posted by NawlensGator on May 23, 2010 at 08:18:36 from (68.155.85.187):
In Reply to: 140 IH transmission posted by Thomas Murff on May 23, 2010 at 05:41:08:
Drain plug is on right bottom of xmission. It takes a 1/2" square socket drive (the male end) and is easy to find under the seat and plarform. The fill plug is the recessed square plug on top of the xmission, just in front of the gear shift. The level plug is on the left side of xmission, 2nd nut toward the front along the bottom of the fender, and toward the front of the xmission. Think its a 1/2" nut. Have to get to the inside of the tire to take it out. Capacity is 5 qts when equipped with a PTO, otherwise 4 qts.
Manual calls for hi-tran but most think 80-90 gear lube works better, including me. If you keep a capped 4" diam piece of PVC pipe over the gear shift lever it will keep rain water out. Look for a milky color in the drained oil to see if water is a problem.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
