Posted by rustyfarmall on May 26, 2010 at 07:19:57 from (209.152.78.140):
In Reply to: high ideling H posted by Farmallb on May 26, 2010 at 06:02:58:
Farmallb said: (quoted from post at 06:02:58 05/26/10) I backed off the screw underneith the govenor tube, But didnt make a difference. Will check choke plate for looseness. It runs perfectly. Pulled a IHC wing disc without the wings, but with RR ties in the weight brakets, no problem
I think you need to completely remove the carburetor. Inspect the ears on the throttle shaft, and inspect the little tang on the shaft coming from the governor, and while you are looking, make sure the throttle plate is still attached securely to the throttle shaft. If all of those things check out, then it is time to remove the cover from the governor and have a look inside.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
