Re: IH 574 no brakes or power steering
Posted by Jimb2 on May 26, 2010 at 19:37:06 from (99.240.236.11):
In Reply to: IH 574 no brakes or power steering posted by jackdonkey on May 26, 2010 at 16:54:47:
Hi Jack, does the parking brake work? Most
hydraulic problems on 74 series tractors are
caused by someone driving the tractor with the
parking brake engaged and the parking brake band
gets ground up into the hydraulic oil. The brake
band bits clog up the hydraulic filter and then
the bypass valve opens allowing the hydraulic pump
to pump the bits all through the system. These
tractor only have one hydraulic pump and the
reservoir is the transmissions and the rear end.
It does not hurt to over fill by 5 gals especially
if a loader is installed.
On 574 the hydraulic pump outputs 12gpm and the
MCV valve splits this into 9 gpm for 3 pt, remotes
and loader, the other 3 gpm goes to power
steering, brakes and PTO.
The problem with your 574 would appear to be a
stuck splitter valve in the MCV valve. It is stuck
in the position so all 12 gpm is going to 3pt,
remotes and loader. Sometimes it can be unstuck by
pulling the remote outlet lever until you hear the
hydraulic relief valve squeal.
Hope this helps
JimB
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
