Posted by M Diesel on May 27, 2010 at 18:14:52 from (70.173.91.228):
In Reply to: 450 diesel pump posted by 450dieselfan on May 27, 2010 at 14:56:01:
Well, presuming the seal is actually working and you got both the thin and thick gaskets back in place with no isues, then it would be back flowing in from the tank return line. That isn't real likely, due to the long standoff pipe inside the tank on the return fitting as well as the pressure relief needle valve being in the way inside the pump. But if the stand pipe is broken/corroded and the needle seeps well then maybe...
There may be something I'm forgetting, but I consider those to be the most likely. Otherwise the plunger assembly has a leak, and that would also require some needle valves to leak as well.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
