See if you have a good spark at the spark plug while having a friend crank it over.
If no spark check for 12 volts at the coil and look at ignition...
If good spark remove the fuel line at the carb and check fuel flow. (also look at inlet filter where the line connects, it could have a piece of rust, rubber..)
If good flow I try a small amount of starting fluid in two cylinders and look at the plugs att the same time - if the look wet or bad try new plugs. If it starts and cuts off you probably have a fuel/carb problem. (my 140 once had an intake bolt that backed out, would only run with the choke on full. Took me a while to figure that one out)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
