couv said: Whichever lift arm DOESN't have a load moves first, then the Lift Arm with the load moves.[/quote:3e249b76ba]
Are you moving both levers? If so, that is normal.
When you move one lever, only the arm connected to that lever should move.
[quote:3e249b76ba]Have to keep the engine revved pretty high to get it to lift quickly.
It is normal for it to be slower in the lift direction than the lower. The reason is that the pump has to fill the entire cavity behind the hydraulic cylinder piston during the lift. When it lowers, the shaft of the cylinder is taking up most of the space inside the cavity, so the pump has to move a lot less oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
