Posted by Zachary Hoyt on June 03, 2010 at 16:45:33 from (184.12.66.187):
Thank you very much to all of you who've helped me with my H. I took the head and gasket down to our local independent tractor dealer/repairman and he checked the head with a straightedge and said it was a little warped but not badly and that he'd try putting it back on. I put a NAPA thermostat in the housing and put that together, put copper coat on the head gasket and put everything together again. At first it didn't have any compression because I forgot to adjust the valves, but after I did it started. The thermostat is working, and when it got up to 150 or so it let the water flow. I put the funny tester back on the radiator and this time I could use it because there were no bubbles coming out. The liquid stayed blue, so I think everything is okay now. I retorqued the head and will check it again in the morning when it is cold before I put on the rocker shaft. I am very grateful to all of you on here who are kind enough to share your expertise with those of us who are new to this. Zach
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
