Posted by keithg on June 04, 2010 at 21:24:36 from (173.28.129.191):
Am starting to work on a Farmall M transmission and will be replacing a number of leaking gaskets & seals (front of countershaft, PTO housing, axle carriers to transmission, etc). When reassembling gaskets do you use any type of gasket sealer or cement along with the gasket? If so, any specific product recommendations? Or will the gasket alone be sufficient to hold 80W-90 gear lube? I also will be opening up the belly pump housing with its gasket--any advice about that gasket? Thanks in advance.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
