If you have a full regulator(as your posts have indicated), you have no need for the Low and High switch, a simple Off is sufficient. You don't need the R position unless you have a combination rear light with 2 leads (evidently you don't). So a 3 position switch is all you need. You can ignore the 4th position.
I'm not sure what you mean by "dramatic". If the engine isn't running, or is just idling, turning on the lights will cause close to 10 amps of discharge. If the engine is running roughly 2/3 speed or more, the generator should put out enough power to run the lights and prevent discharge.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
