Initially I have more questions than answers, but will try to help. Do you mean that the engine can only be started with the clutch pedal depressed (clutch disengaged)? Can you roll the tractor back and forward with the transmission in neutral and clutch engaged? Can you roll the tractor back and forward in all of the gears while the clutch pedal is depressed (clutch disengaged)? While I do not not primarily support your assumption that the transmission input shaft bearing is bad, you can easily check that by putting the shifter in neutral and pulling the transmission cover. Try to wiggle the input shaft. My guess is that something is wrong in the clutch area (fork for throwout bearing collar, throwout bearing, cluth fingers, pilot bearing). Hendrik
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
