I think the clutch is still OK, It may need a new T/O bearing and spring, but I might replace the disk if it shows wear. The symptoms might be indicating a locked bearing in the trans main shaft. (either front or rear) In that trans, the lay shaft takes out the power. so in neutral, there is nothing in gear to the main shaft, allowing the rear to be free to roll in Neutral. If the main shaft was frozen the clutch would also lock up the engine when the clutch is engaged (trying to drive the trans). Best of luck. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
