Posted by karl f on June 11, 2010 at 09:01:25 from (172.129.151.20):
In Reply to: alternator update posted by jdemaris on June 11, 2010 at 06:39:14:
jdemaris said: (quoted from post at 06:39:14 06/11/10) No, it does not have to be complicated. It becomes so when you don't have all the data/info.
What model of 10SI? What pulley ratio and RPM at testing? What regulator? Was a thorough bench test done?
this is a freebie off of source unknown. believe it's stamped around 60amps. A new reman #7127-12 i tried behaved the same although it at least cut in at 3/4 throttle. I sure don't mind buying a new if needed since i have a core but when they behave the same I do not know which way to go.
The tester at work definitely spins faster than the tractor ever could with real world pulley sizes. it looks like at least a 4 inch drive pulley. The motor is inside the steel cabinet so i cannot see the specs. It is not variable speed and basically a volt meter with a charge light and 100s of harness adaptors. Made exclusively to decline warranty claims IMHO.
The tractor is a 400 farmall. I used a 3 inch pulley on both alternators originally. This time I used about a 2.5 inch. my previous posts were asking about pulley drive rpm and your post Jdemaris tells me the goal rpm of the alternator. the 400 drives the waterpump pulley about 1.5:1 to crank, and the waterpump in turn drives the alterator with a 4 inch pulley.
the new alternator paperwork said cut in rpm was around 250 so i don't know why it wouldn't work. I figured if the new and old acted almost the same to use the old...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
