The alternator is simply a little "off" of "spec" and won't excite with the current you are feeding it through the lamp.
Just for GIGGLES, temporarily connect a second lamp in parallel with the first and see if it will excite, or try a 50 Ohm resistor across the lamp.
If that works, you can leave the resistor in place, ASSUMING the alternator doesn't have internal "leakage" that will drain the battery when it sits unused.
Otherwise, you need to replace the alt, or tear into it and check the stator, the rectifier, and the diode trio. If those check out OK swap in another regulator and see what happens.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
