Posted by karl f on June 11, 2010 at 22:23:35 from (172.162.50.248):
In Reply to: alternator update posted by karl f on June 10, 2010 at 23:05:08:
Thank you to everyone.
I'm going to try the 194...
and then probably take the alternator to the local rebuilder to have it built to my needs. It will avoid the experience of having an off the shelf unit not work exactly as needed.
I'll try to get a copy of that low cut in rpm spec sheet.
I can't spend much more time on this, I have my wedding in a month and much to do before then. After will be focused on the new relationship so it's like i'm runnin out of time. There were some suggestions i would have liked to try--I will get an assortment of resistors for next time.
Today i had a chance to do some digging: the bench tester spins at 1750 rpm and has a 4.5inch pulley. any marginal alternator will pass that test!
I never did any internal tests, i should learn to do those for that one day when they'll explain the symptoms.
Thank you to everyone. I hope i responded to your questions even if i did not address you directly. I appreciated all your help and found all the posts useful.
I'll let you know how it comes out.
thank you
karl f
wondering what would have happened if he went with a 10DN instead... :)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
