Posted by Jimb2 on June 12, 2010 at 19:11:01 from (72.38.123.67):
In Reply to: 585 loader hookup posted by MikeinKy on June 12, 2010 at 14:56:28:
Hi you can spend many $$ at CaseIH and by a power beyond plate for the end of the aux remote valves. IF you never use the hydraulic remote outlets then you can connect the IN side of the Joystick valve body to one remote outlet and connect the OUT to the other remote outlet and tie the remote outlet lever back so the remote outlet is open. If Joystick is working in wrong direction, just swap the hydraulic pipes at the remote outlets.
If you require use of the remote outlets at same time as loader then the cheap way to install Joystick control valves is: Removed the aux hydraulic return tube from the aux control valves to the draft control module under the seat. See tube at caseih.com parts for 585 hydraulics page 8-450 item 18 Tube assy Aux Valve return.
After you decide your method of connecting the Joystick valve then post again and I will supply more detailed instructions.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
