3 Amps rating should suffice for the alternators required initial excitation current and 100 volts withstand rating is plenty so YES it should work okay, rememember its polarity sensitive so for Neg ground its Cathode band should be towards the alternator.
NOTE instead of a diode one can use EITHER a 10 ohm 10 watt resistor (no worry about polarity) as it also prevents the run on problem PLUS provides some degree of current limiting safety ORRRRRRRRRRR instead one can use a small incandescent idiot light charge indicator to be on when shes NOT charging but off when she is ORRRRRRRRRRRRR use the idiot light in paralell with the current limiting safety resistor so she can still charge should the idiot light burn out.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
