After it dies, pull the small plug on the bottom of carb. If no flow, screw it back in. Tomorrow, do the same thing before starting the tractor. If you only get a few ounces, you need to look at the float sticking to inside wall of carb, the fuel inlet screen at carb, the fuel pipe between the carb and sediment bowl, the flow out of the sediment bowl, the fuel port out of the tank. If the last is just dripping fuel, put a small hose over the outlet inside the sediment bowl casting and blow with your lungs. The fuel should pour out after that. The tank will need to be cleaned as your problem is only temporarily fixed.
A sticking float can sometimes be fixed by rapping the side of the carb with a small hammer.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
