Re: MTA Split problem
Posted by sflem849 on June 15, 2010 at 07:13:07 from (69.197.84.192):
In Reply to: MTA Split problem posted by couv on June 14, 2010 at 19:50:12:
For those who haven't been back and forth
The tractor vet said: (quoted from post at 20:37:12 06/14/10) Good grief , Pull it back apart and remove the pressure plate and place it on the floor and use your hgeel and push one release lever down at a time and lock the lever down with a 1/4 inch nut then do the next and then the next this hold the pressure plate in the release possession . Next hang the pressure plate on the PTo input shaft then hang the clutch disc in the transmission shaft and slid it together , Then remove the inspection cover off the bottom of the bell housing and work up thru the bottom and bolt the pressure plate to the flywheel . This ain't rocket science it a flippen tractor. Oh and it really helps if the bell housing is clean or you will have grease clean up to your arm pit.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
