No, only 1 wire goes to the F on generator and with your regulator it would be from F on regulator. The regulator is automatic so we give it priority.
You could either completley remove the gray wire from the L on regulator, or disconnect the short red ended wire which now connects on the ammeter with the green wire and connect this red wire to the L terminal. This is the wire that feeds the light circuit.
Then the regulator will automatically control generator output and you would use the switch for lights only.
The switch had the light section and the Hi-Lo generator section. They switched together but were separate systems so there is no problem switching just the lights with the switch.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
