Re: Farmall 450 Power Steering
Posted by pete 23 on June 16, 2010 at 11:18:25 from (173.87.0.80):
In Reply to: Farmall 450 Power Steering posted by Alan Sperfslage on June 16, 2010 at 09:01:57:
My question to you is , if you hold an aux valve lever on demand will it steer better. If it does that indicates that your flow divider valve is worn and leaking past the lands, common problem. If it does not steer any better it would indicate a leaking steering unit, or relief valve, or weak pump. The flow divider spool is available at CaseIH, and easy access to replace. If new spool doesn't help, then valve body is worn also and it gets really expensive to have them rebuilt.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
