Just use a Prestone cleaner, or equivalent. HOWEVER, you will not get everything out. That system has 59 years of thick crud in it, and will not come out unless the radiator is rodded by a radiator shop (and will probably fall apart in the process) and the block and head hot tanked. As a compromise I put dilute HCl in my Super H, with the radiator off, then flushed repeatedly with baking soda (Sodium bicarbonate). Merely telling you what I did, not a recommendation. Acid must be neutralized, it cannot be removed with water. It is reasonably clean. Also you should replace the cover/water distribution piece on the left side of the engine. It will be rusted through inside.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
