Posted by Janicholson on June 19, 2010 at 07:23:05 from (64.61.211.76):
In Reply to: Alternator troubles posted by Zachary Hoyt on June 19, 2010 at 04:50:33:
The assumption that the Prior owner did it correctly is the issue. A single heavy 10 Gauge wire runs from the alternator main post to the amp gauge terminal that does not go to the start switch. (load side of gauge) A single wire goes from terminal #2 on the edge of the alternator to the alternator main output post (short wire). The #1 post is connected to one terminal of a side marker light bulb (or a 3 amp diode with the band on the diode toward the alt, or a 10 ohm 10 watt resistor). The other light bulb lead goes to ignition voltage. (or if it has a magneto, battery voltage through a oil pressure switch that is on with pressure (NAPA) then to battery volts at the starter switch). It could have a manual switch to excite (yours may) but this is sure not the best option. Jim
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
