Posted by pete 23 on June 29, 2010 at 19:10:15 from (173.87.147.99):
In Reply to: H fifth gear jumps out posted by jerry hakenwerth on June 29, 2010 at 17:02:10:
Once you get a wear pattern on a gear from jumping out of engagement it is difficult to overcome, however, I have had some success with adding a washer behind the rear bearing on input shaft to put it back a little farther. Problem is you already have cover off so it would be a lot of work for nothing if it doesn't work, but then, labor is cheap on your own rig. Loose bearings on the input will of course have to be taken care of also, and pilot brg. When cover is on,trans in fifth gear you can readily see if it is getting a good bite on input shaft and still not being forced against fork. Might get a little constant mesh gear noise but I just did an M and it is quiet.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
