Posted by glennster on June 30, 2010 at 17:31:47 from (99.90.9.153):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
if its 12v neg ground, the - wire should be connected to the ignition points. if its still 6v + ground, the + side should be connected to the points. even if reversed, it should still fire. get a test light and hook one end to the hot side of the battery, with the ignition points open, remove the wire from the coil that goes to the points and put the test light on the wire. if the lamp lights, the points are grounding out. check the insluator where the wire connects to the side of the distributor to see if the insulation is bad, or if something is touching to ground out the points.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
