Posted by tractorsam on June 30, 2010 at 17:45:54 from (24.222.151.46):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
If the points were closed when you did this test that would be entirely normal. The purpose of the points is to take the power to ground, the coil is the load, and so after the load the voltage will be zero (it's voltage rather than current that you see with the test light) if the circuit is complete (points closed). If you have an assistant crank the tractor while you watch the light (connected on the distributer side of the coil) you should see it flash as the points open and close. Hope that helps, Sam
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
