Posted by pete 23 on June 30, 2010 at 18:49:44 from (173.87.147.99):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Just to add to what Sam said, turn engine until points are open, then you should get a test light to light up on both side of coil, + and -. If you do not get a light, you have an internal ground like condenser or lead wire is touching side or you do not have continuity through primary winding of coil. That is easy to find out by unhooking wire to points and if you get a light then you know current is available through coil. If these things check out, what I do is, pull high tension wire out of dist cap, with switch on and points still open , all wires hooked up, merely make and break contact of the terminal at points or coil with a screw driver or what ever, which will simulate points opening and closing, and you should get a nice healthy spark to a good ground out of that high tension coil wire. Tells you if coil and condensor and all wires leading to it are good.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
