Posted by Brian Schmidt on June 30, 2010 at 20:31:56 from (69.66.237.6):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Need to find out if you got spark or not. When you say no fire I assume you mean it wont start. Pull the wires off at the dist and check contnituy to ground. Should be nothing when the points are open and a direct short when closed.
Then if that is good move onto the coil. If you are 12v neg ground then it is neg side of coil to the dist. And a hot switched wire on the pos side. If that is all good and you still got no spark, pull the condenser out and try it again. Could be shorted. If that still gives nothing, then replace coil.
If you are 6v pos ground, then switch the pos and neg directions on the coil for optimal performance.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
