Re: *Super M Again*
Posted by mkirsch on July 01, 2010 at 05:01:09 from (64.80.108.56):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Whatever's wrong, it's a simple and obvious problem. There's no magic involved here.
Problem is you've been struggling with this problem for so long that you've developed mechanic's blindness. You're checking things off in your head instead of actually checking them physically. Yup, I did this. Yup, I did that. Yup, I did the other thing...
You need another set of eyes on the issue.
You've got no fire...
Is the distributor turning?
Does the coil spark to ground when you remove the center wire off the distributor cap and hold it to the engine block?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
