Posted by Owen Aaland on July 02, 2010 at 00:58:44 from (65.161.86.20):
In Reply to: H stuck on TDC posted by rmthunder on June 30, 2010 at 20:22:20:
When the starter locks the engine the problem is worn teeth on the drive and possibly also the ring gear. Usually replacing the starter drive is enough to correct the problem. If there are teeth burred over on the ring gear you can make it serviceable but filing off the rough areas. Just make sure the surface that the drive pushes against is smooth.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
