Posted by RustyFarmall on July 02, 2010 at 07:27:31 from (209.152.78.140):
In Reply to: Gov Weight Pins... posted by CoopertownBob on July 01, 2010 at 20:24:27:
On a couple of my Hs,I used some 1/4" long shank bolts. Make sure the shank on the bolt is long enough to pass through both the bracket and the weight. Cut off the threads so there is just enough left install a nut, carefully tighten down the nut so you don"t limit the movement of the weight, and then either tack weld or stake the nut so it can"t loosen up. If I remember right, I had to use a dab of valve grinding compound on the shank of the bolt to "fit" it to the hole in the weight.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
