3 pt will not go down: Maybe the unload valve is stuck. Check with engine running, raise the hitch and at same time pull the remote lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow the dirt out with air. Replace the O-rings with new ones. OR There is a cover on the right side, in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, may be that spring is not unhook. Bernard le mécano Québec Canada
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
