No rules here on that topic. If the governor output shaft (and linkage is not moving, you are going to need to go into the governor. Do not allow it to run over speed, as there will be drastic damage. If the link from the throttle control lever is moving the lever on the governor through its full range, it is internal to the governor. They can have any problem from broken springs to bad bearings, to weights off of the spindle. A manual is needed. caseih.com has a parts diagram on line. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
