Posted by Tom Fleming on July 04, 2010 at 19:28:32 from (206.193.253.243):
In Reply to: Ignition Switch posted by Bud W on July 04, 2010 at 13:18:52:
You can make a distributor IH switch run a mag, but you can't make a mag switch run a distributor.
Mag switch = 1 terminal on the back
Dist. switch = 2 terminals on the back.
If you want to make a dist switch work with a mag, run 1 terminal wire to ground, and the other terminal wire to the mag. then, you will push it in to run, and pull it out to shut off. Kinda hokey, but I have done it in a pinch until I was able to get the correct switch.
so, depending upon what type of switch you are buying, will make a different only if you have a distributor ignition. If you have a mag, doesn't matter unless you want to be "correct".
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
