Posted by gatorhide on July 05, 2010 at 11:28:03 from (24.155.13.131):
Well, the M still won't run.
I tried to start it and when I let off on the start button, it continued to turn over. I had to disconnect the + cable in order for it to stop turning over.
Is the new push start button malfunctioning ? Or is it the new on/off switch malfunctioning ? Or both ?
I took the distributor out and examined the stud bolt and the insulation on both inside and outside of distributor and did not detect anything there appearing wrong. I also made sure the points are set @ .020
When I tried starting the M again, it would backfire and this would be incorrect timing, but I couldn't get it to start so I couldn't set the timing.
I'd forgot to make a mark where the distributor was set at before removal.
Today's Featured Article - The David Brown Rose Badge - by Samuel Kennedy. In the 13th century civil war was raging in England. Two English noblemen were involved in a conflict which became known as the War of the Roses. The Duke of York had as his emblem a white rose and the Earl of Lancaster had a red rose. Today the white rose is the official emblem of the county of Yorkshire and the red rose has been adopted by the neighboring county of Lancashire.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
