The front gears only need to be timed if you are using a magneto. Even then it is possible to install it from the rear and get it timed correctly.
For a distributor just install the drive and then make the timing adjustment when you install the distributor into the adapter housing.
For a magneto turn the engine to TDC on number 1 compression stroke. Use a mirror to locate the timing mark on the front of the camshaft gear. Mark the tooth (or two teeth if the mark is between teeth) so you can see if from the back side of the gear. Locate the mark on the driven gear and match it to the correct teeth on the camshaft as you install it.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
