Yes, because the barrel that couples to the crank is usually seized. Then there is the stamped spring retainer which is likely to be seized on the barrel as well as the 1/2" dia pin.
If everything has been gobbed up with grease for the past sixty years, it's not a big deal. Otherwise, you will probably have to remove the bolster. Bear in mind that the job requires one to work on his back with his hands inside the bolster casting. Do you have any 5-6 year olds in the neighborhood who like tractors.
Think about compressing the spring with several tie-wraps.
I did this partial disassembly to slide the barrel back far enough to install a 2 groove pulley on the crankshaft. This was an old bolster I had to see if it could be done before attempting the same job on my 400.
As I look at these pictures, I am not even sure that the barrel will come out if the bolster is still attached to the frame rails. I have only removed barrels on separated bolsters. Perhaps you don't need to replace the barrel. You haven't indicated what the problem is.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
