mkirsch said: (quoted from post at 14:09:16 07/08/10) Are you saying that you put the resistor BETWEEN the coil and the distributor?
You need to put the resistor between the ignition switch and the coil.
That's why the coil is getting hot.
If you make a drawing of the electrical circuit you can see that it makes no difference in the primary circuit which side of the coil has the resister. The resistance of the coil and the resistance of the resistor are in series so the current draw of the coil will be the same either way. By putting the resistor on the battery side of the coil it is possible to bypass it for more voltage for starting.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
