There are an assortment of issues here: It was not 12v from the factory, so it isn't "stock" but that is OK. One polarizes the generator by jumping Bat to Gen on the regulator. (the VR is not polarized by jumping it might have polarity if it has solid state parts in it, and some new VRs do, but it is usually able to charge either polarity. The charge rate is a little high at 16v but two other things are important. The use of a DMM is frequently impossible on these unless you pay for a Fluke meter or equal. THe sample rate of the meter grabs information on a noisy (irregular to beat the band) voltage source, and will not average the spikes or valleys it encounters. An analog meter with a needle is usually the much more accurate answer. A bad Vr would cause a bat to drain, but it would also heat up wires and heat the generator, if it did. Thus the drain is either a light that is on, the ignition switch is not turning off all the way, or (most likely) the battery has a bad cell in it. I would check the battery first. It is easy, charge it up with one terminal disconnected from the tractor, then let it sit for a few days and measure the voltage. The DMM will work here! If it is less than 12v, and will not start the tractor,, it is bad. I think the charging system may be OK. Good luck, Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
