Posted by Janicholson on July 11, 2010 at 20:13:19 from (64.61.211.14):
In Reply to: Re: H liftall posted by Zachary Hoyt on July 11, 2010 at 19:13:41:
If I recall, 6" down from the cap neck will be full. it is very not critical. It is small, and for a loader with single acting cylinders, an auxiliary reservoir is used. T it into the bottom of the Liftall drain, and keep it about the same height, If using 2 way cylinders, the cap on the original reservoir can be non vented. If using a bigger reservoir, that can be vented and higher than the original fill port if the original fill port is capped off W/O vent. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
