Re: Farmall A diff oil and capacity?
Posted by ScottyHOMEy on July 13, 2010 at 20:09:49 from (70.105.249.70):
In Reply to: Farmall A diff oil and capacity? posted by danieljohnson on July 13, 2010 at 17:41:47:
The 80-90 gear oil is fine. Drain plug for the tranny is on the right face, at the lower rear, behind the diff shaft housing. Fill level plug is diagonally opposite, a short distance up on the front of the left face and much smaller. Usually a square head pipe plug, the brake actuating rod will be a little in the way of a wrench when removing and replacing it. As for capacity, 5 qts for the tranny, figure on another half quart if you have a pto/belt pulley. That unit will also have a drain plug. My practice there is to drain both and refill through the fill plug on top of the pto, as all the excess will drain right down to the tranny. If it takes significantly less, you can figure you've got a lot of sludge inside and may want to think about cleaning it out.
If you want to do the final drives, as ws mentioined below, that will involve dropping the pans on the bottom of each. Its the only way to drain them and you might just as well plan on new gaskets for them. Refill on each side is three pints, delivered through a hole with a large pipe plug found just fore of the cap over the inner end of the axle on each side.
As a gentle suggestion, I'm gonna recommend you spring for an Owner's Manual if you plan to run this tractor. It will answer many of the real basic questions about operation and maintenance.
As for motor oil, the stuff has advanced so since the oils available when the Owner's Manual was original, that that is one point where it is obsolete, so I'm gonna say it's your preference. It's been hashed over MANY times here. Some favor 10-30, others 10-40, some swear by straight 30 (detergent/non-detergent is a whole other discussion). Some run nothing but the same 15-40 they put in their diesels. Each has his own reason for choosing the oil he does, with variables like weather and use factoring in, but I haven't heard anybody complain of wearing their motor out for using the wrong oil. Regular changes of oil and filter will be more important no matter what weight you use.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
