Well , the dump valve maybe sticking or ya may have either a blowen gskt in the MCV or a blowen or missing O/ring in the MCV . If you plan on playen with the DUMP valve then do a full adjustment of the clutch and trans brake also starting off with the free travel on the clutch pedal first then the trans brake . If the steering is weal then you are also having a loss of pressure as it all runs off the MCV pump and NOT the rear hitch pump.as to nailing i down over the magic box that ain't ah going to happen I myself Pete or Owen would have to do some pressure testing and a flow rating of the MCV pump would tell us a lot more. Now we could take a chance and tear into the MCV pump and see what is going on there with a new Gskt. and seal kit and a new spring kit and may help some and maybe a new pump if needed , But that will not cure the low side issue only a new T/A unit will solve that and since you there ya might just as well put a new clutch and PTo input to her and be done with it . It only hurts for a little bit when ya write the check.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
