Posted by jeffalex2 on July 17, 2010 at 03:53:31 from (71.246.72.180):
In Reply to: H battery discharging posted by Drewbee90 on July 16, 2010 at 17:42:50:
Need a little more info...are you running battery or magneto ignition? 6volt or 12volt? Generator or alternator? If you are running factory 6volt set up with a magneto, the most likely culprit is the regulator is defective or wired wrong. Does the ammeter show a discharge when the tractor is shut off?
Also, don't rule out defective battery. I racked my brain for 2 weeks over a bad Napa battery on my Super M. Take the battery out of the tractor and make sure it holds a charge by itself. While disconnecting the battery, take off the negative terminal 1st and try and see if there is a small spark while you remove the terminal, if so, then you have a short in the tractor somewhere.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
