Posted by MRJHG on July 19, 2010 at 05:37:12 from (24.179.63.7):
Problem: Rear pushrod has broken 3 times. Motor runs fine for hours until it happens again. The valves are set right (12). With valve cover off and engine running everything looks, sounds and feels right. Lifter appears normal by flashlight.
Recent history: I have replaced the rocker shaft assembly due to failure of rear mounting stud. Tractor has not been right since a guy installed my rebuilt injector pump and got the timing way off. It has been corrected since then.
Questions: Any ideas? Would I be able to see cam by removing the crank case cover on the side of the block below the exhaust manifold? What is exact torque of rocker shaft studs?
Please help. I"m getting tired of chasing my tail!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
