Re: 460d questions
Posted by pete 23 on July 21, 2010 at 18:56:14 from (173.87.9.157):
In Reply to: 460d questions posted by 460guy on July 21, 2010 at 18:05:16:
Yes, you can check the primary pump pressure which is the control pressure that supplies internal injection pumping plungers and the auto advance. You need to study the manual a bit and see how this is done. I cannot tell you what you need to know online here. You for sure have to adjust the load advance mechanism. If it is not working correctly the engine will run terrible. I have seen more people pull injection nozzles out and bring them in to me to test when what is really wrong is the adjustment on the pump. If you were anywhere around here in western Minnesota I would sure help you out but doubt you are. If you go to an injection pump shop and get a window to put on the pump, they cost very little it will help you immensely. Good luck. Oh, far as leaking injection nozzle, depends on what is leaking but it sure can be repaired. Leaking fuel or combustion, either way , can be fixed.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
