Posted by Janicholson on July 25, 2010 at 19:02:10 from (67.72.98.45):
In Reply to: Cub Won't Start posted by Roger46 on July 25, 2010 at 17:57:01:
Yes A fast cranking Mag will spin so fast that the impulse coupling will not engage the housing. this results in way advanced timing, and not enough rotation of the magnet to make good spark at starting, not running speed. I would try pull starting it if you and the pulling person are solid with the protocol of pull starting a tractor. Do not if at all nervous! If it runs when pulled, the impulse system in the mag drive might need to be fixed.
If you can hear the mag coupling snapping (as it does when hand cranking) it might be something else.
Heat up the plugs with a propane torch to get them clear of shorting material. put them in warm. It helps a lot. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
