It's quite simple. If you remove the engine oil pan you'll see a strainer hanging down that the oil is sucked up through, I believe it's retained by a single cotter pin. Once you've removed that you'll see that the bottom plate of the oil pump (which the strainer hangs from) is only made of pot metal. Often they warp/wear and either allow enough oil to bypass and cause a pressure issue or due the warpage the gasket will blow out. Remove the four bolts that retain the bottom cover, be careful as one of the oil pump gears will also likely fall out. Once you have the cover plate off you can either get it machined flat, use a piece of course emery cloth on a flat surface (such as a robust sheet of glass), or if you're very good file it flat. Hope that helped, Sam
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
