Posted by jdemaris on July 29, 2010 at 15:22:53 from (67.142.130.11):
In Reply to: B-434 carb posted by 550Doug on July 28, 2010 at 18:58:01:
Why not just fix it? The British Zenith VN is the better of two models - VN and VNN. It's just a 30 mm downdraft carb and is also used on several small British cars. VN has the accelerator pump and economy valve, whereas the cheaper VN has neither.
Most that I've taken apart, I didn't even need new gaskets. Thottle shaft, float, etc. are all still availalbe.
If you just want to bolt on something else, you need a down-draft 30 MM carb with two bolt-studs that are 2 3/8" on center for mounting. Volkswagn used them years back in the Beetles (Solex 30MM). Some military Jeeps also use downdraft 30 MM carbs.
By the way, British-Zenith no longer exists. It bought by Solex and then, those carbs were phased out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
