Pull off a plug wire and hold it away from the sparkplug about 1/4". Then have a helper to make an attempt to start the engine. If there's no fire rub the points with a piece of 320 wet or dry then see if the engine will start. If it starts you've found the problem. If there's still no fire to the plug you need to use a volt meter to see if you have battery voltage at your coil with the points open. You need the ignition switch in the on position too. Look at those points if they're pitted replace them and the condenser.
Run a separate wire from your battery to your coil then see if the engine will start. Hal
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
