Guys, If I am letting them set for a while just ATF & DSL. If at all possible fill up the cylinder with a 2/3s to 1/3 mixture of ATF and Diesel and replace the plugs for a couple of months or so. If that does work strip tractor down to the block, roll out side, and fill cylinder with most volume with DSL add a splash of gas, set on fire and let the fire burn itself out and then drive out the piston from the bottom up. Move to next most volume cylinder and repeat, till all pistons are removed. Note as the volume goes down so does the burn time, so a 2nd, 3rd, 4th and so on may be needed to break loose the rust so the piston will come out. Hope this helps! Later, John A.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
