Posted by Roger46 on August 01, 2010 at 10:35:04 from (75.221.226.167):
Last week I posted a message about my Cub that wouldn't start after being at the Wisc Farm Tech Days. It had spark, gas, and compression, but would not fire. I finally discovered that it didn't have sufficient spark. It turns out that the magneto got wet inside the coil area as well as the top cap. The only way I was able to completely dry it out was to heat up the magneto with a heat gun and put the top cap in the oven (wife not real happy about) for about an hour. It is an old top cap and must be bakelite as it seems to have absorbed water; because I first dried it with the heat gun, but it became wet inside again after sitting overnight. Also, I discovered that the tang inside that contacts the coil was broken and not making good contact with the coil. Fixing that and drying it out, the Cub fires right up. I was surprised that it wouldn't run with the spark it had, but must not have been enough. I did what someone had suggested and opened the gap on a sparkplug to about 1/8 inch and it wouldn't fire, but my Farmall B magneto would easily fire across that gap. Thanks for the suggestions. Roger
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
